跳转到主内容
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
Can the hard drive be upgraded?
Can I upgrade the hard drive in my Asus Chromebook C201?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Sadly, you can not upgrade the hard drive in the traditional sense. In fact, this Chromebook does not even have a hard drive installed. It uses something called an eMMC. This is a flash storage card that is soldered onto the motherboard. It’s similar in size and shape to an SD card, but is closer in function to a solid state drive.
While the eMMC in the Chromebook is only 16gb, you can offset the small storage capacity by using Google Drive. The Asus Chromebook C201 comes with 100GB of free cloud storage for 2 years.
这个答案有帮助吗?
得分 4
3条评论:
This Chromebook also has a micro SD slot that can be used as a local hard drive for up to 128 gigs of storage.
完成的
No, but it can be used for storage.
完成的
I wanted to explain Ammar Rauf's post and Bryan's a little more. The eMMCcard can be desoldered, and there are 32 and 64GB eMMCs, if you can find out which ones are compatible. LabOne is in Pakistan, so shipping your Chromebook there might be a tiny bit expensive.
完成的
添加一条评论
Now you can upgrade all the Chromebook storage up to 64gb
https://www.laboneinside.com/we-can-upgr...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robert Lawson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 17,673
