跳转到主内容
加入维修社区 - 创建账户
关于苹果第六代 iPhone 的维修信息、故障排除技巧和指南,发布于 2012 年 9 月 12 日。型号:A1428,A1429
SIM card not supported
Ok, so I just bought a phone off craigslist. I had Verizon check it before I bought it. They said its fine. I tried installing a Verizon SIM card. Won't accept it. Said sim not supported. I checked the imei, says its for Verizon. Can't get into this phone now. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 31
17条评论
iphon5 sim card not sported after unit replace
由完成的
same as mine. what would I do??
由完成的
what to do??
由完成的
Sometimes the SIM card is to much advanced to the phone. Once I had a SIM card that had just been delivered to me by the operator and when trying on the phone, it was not supported, but when trying on a newer phone the card already worked. Both mobile phones were from the same operator.
由完成的
My iphon 5s support AT&t sim and when i wan to change it to my country sim card .that,s alart (the sim card is not supported)
由完成的
显示更多的12条评论
添加一条评论
6个答案
已选择的解决方案
Yes. It could be a replacement unit that was activated with a GSM carrier SIM right after replacement, and got locked to that carrier. Should be T-Mobile or AT&T.
Now Verizon see it as theirs but can't unlock it because well, it's not locked to them.
Try AT&T and T-Mobile SIMs. What happens?
这个答案有帮助吗?
得分 24
8条评论:
I tried a T-Mobile sim. It doesn't work. I can try to find an AT&T sim and try that...
由完成的
Sim not supported how can't do?
由完成的
由完成的
If SIM is not supported it means your device is locked to a given carrier, and you are trying to use a SIM from a different carrier.
Either you must unlock your device (by the carrier or some unlocking services) or use a SIM from the supported carrier. Or sell the device.
由完成的
My sim mot supported. How i unlocking
由完成的
显示更多的3条评论
添加一条评论
sim not sport help me
这个答案有帮助吗?
得分 2
1条评论:
Yes my phone IMEl number change please help 🙏 me
由完成的
添加一条评论
Mine just started doing this when I go out of Verizon's range. Verizon says there is nothing wrong on their end an apple says its Verizon. So idk but if you have figured iit out can you post what you did to fix it? I think maybe switch to at&t is the answer.
这个答案有帮助吗?
得分 1
1条评论:
My phone IMEl number change please help 🙏😭 me
由完成的
添加一条评论
I need your assistant with my iphone 5c which i have a displayed on my screen that sim not supported and i was giving the phone by a friend of mine which she is in Tx while am in west africa , here is my imel number for your help imel 013996001280639 …. Awaits for your response in my box camkin2323@gmail.com
这个答案有帮助吗?
得分 1
4条评论:
Hi I bought an unlocked iphone xs max at bestbuy. It’s working good when i inserted my at and t sim. Now, im in the philippines and I thought it will just work fine because I bought it as unlocked. To my surprise it, a message in my phone appeared saying sim not supported. I tried all local sim but not working. Can you help me?
由完成的
Problem solve ha
由完成的
Please help 🙏 me
由完成的
Your number really
由完成的
添加一条评论
Factory unlocked phones have no issues that support all the carrier,But if the problem with Gevey users that is panic after the update of last or who wish to change the new carrier.After the update of the 10.3.3 most of the gevey users
have problem with activation error.I found the solution and wish to share with the friends who got that problem.The solution is you need to jailbreak the phones,Remember that makes your warranty void.
You have to remember that activation server only works on IOS 12.3.1 till date.The iccid that you can`t put on that ios because apple disable the emergency call input ICCID function too.This tutorial is helpful for those friend who encounter with that problems.
这个答案有帮助吗?
得分 1
添加一条评论
turn the phone off and turn it on again after put your sim card in sim tray . after 1 minute go to setting turn on airplane mode after 2 min turn it on after back to network select search network automatic.
这个答案有帮助吗?
得分 0
2条评论:
I can't get into the phone. I'm in setup
由完成的
My phone IMEl number change please help 🙏 me
由完成的
添加一条评论
添加你的答案
iMedic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 83,800
