My tablet wont charge anymore already tried differt charger?
I have already tried different charger and pu different filemate tablet on my charger... Why won't my tablet charge?
lunakrazyshedevil71 if your charger work properly, then it is possible that you are having issues with either your battery or your charging port. Use this guide for the battery. While you check/change your battery take a look at the charging connector soldered to the logic board. You may have to resolder it or replace it.
这个答案有帮助吗?
I don't think its a battery issue due to his loose charger fits now.... Can I use USB port?
No it is not made for that charging
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 232
3条评论
lunakrazyshedevil71 the other tablet you tried charged with your charger?
由 oldturkey03 完成的
Oldturkey03 yes the other tablet charged up withmy charger..the charger fits tight on other but is loose on mine.. Charger is not like most cell phone chargers... Can I use the USB port to charge?
由 lunakrazyshedevil71 完成的
I don't think its the battery due to the way charger fits
