跳转到主内容
加入维修社区 - 创建账户
G4 Quicksilver 拥有 533MHz、667MHz、733MHz、800MHz、933MHz 和 1.0GHz 等多种频率规格。
Pressing power button does not turn on
Pressing the power button, Unit does not turn on. Button lights up for a split second, drive does not turnover. Disconnecting power cord and reconnecting does not help. Is the problem the power button or the drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
It's probably the power supply. Do you get any diagnostic lights on the logic board?
UPDATE 2/26/16
The diagnostic LEDs should lit up when you press the power on button if the power supply is good.
There is also a CUDA logic board reset button on the logic board. Press the CUDA button, ONCE! It is located to the rear of the battery housing. It looks like a small pencil eraser in a metal square..
Have you replaced the 3.6V/850mAh 1/2 "AA" Lithium PRAM battery?
这个答案有帮助吗?
得分 2
2条评论:
I will check. Will lights be present on the logic board with plug connected and the unit powered off though?
由完成的
Did you ever fix it?
由完成的
添加一条评论
添加你的答案
Mik B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,152
