跳转到主内容
加入维修社区 - 创建账户
Roku 3(型号:4200)是 2013 年 3 月 5 日发布的一款第三代流媒体设备。通过正确的输入连接,将其连接到任何电视或视频显示器,即可流式传输可用内容。
controller will not work
my roku 3 was working fine. then the controller quit working. I put new batt. in it, did not make a difference. Then I pulled the power cord from the unit. Thinking it would reset it self, it worked for several clicks then quit. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Try this trouble shooting guide: http://mkvxstream.blogspot.com/2013/01/s...
这个答案有帮助吗?
得分 2
添加一条评论
there was small issue in this http://www.showboxmovies.org
这个答案有帮助吗?
得分 0
添加一条评论
If the controller is working randomly the problem is most likely the carbon contacts on the back of the rubber pad inside are covered with food oils and debris. When the buttons are pressed the dirty contacts remain open. Carefully disassemble the hand piece watching where everything fits. One screw behind the batteries and snaps around the perimeter hold it together. Clean everything with alcohol and hand soap, except the circuit board, then dry thoroughly before reassembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mgopp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 419
