跳转到主内容
加入维修社区 - 创建账户
failed evap vent solenoid
how to fix code P0446 on a 1999 chevy tahoe
probable cause
purge or vent solenoid defective
saturated vapor canister
failed evap vent solenoid need to know what parts to get to fix
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Have you been to all your local auto parts stores?
完成的
添加一条评论
4个答案
已选择的解决方案
Evap vent valve has only one purpose. It closes in order to seal the vent so the EVAP system can pressurize and ensure there are no leaks. Evap vent valve is usually supplied Battery voltage with key on. The ECM's driver controls the ground, and when grounded, activates the valve (closing it). If the ECM detects a short to ground, and open,or a short to battery voltage on the control circuit, P0446 will set. Code also may refer to ECM detecting that EVAP system is unable to achieve or maintain vacuum during test.
Symptoms
There will be no obvious symptoms to driver, other than MIL illumination.
Causes
A code P0446 could mean one or more of the following has happened:
Faulty vent valve
Open, short or excessive resistance on Vent valve control circuit
Blockage of vent valve
Bad PCM
Possible Solutions
With a P0446 OBD-II trouble code, here are some things to try:
Replace Vent valve
Repair open, short, or resistance problem in control circuit
Repair open, or short, or resistance problem in power circuit
Replace PCM
Check the sensor in the engine
Replace the Vsv for the charcoal canister
Look for a disconnectted or damaged hose around the air filter box that goes the evap solenoid
这个答案有帮助吗?
得分 2
1条评论:
complete answer +
完成的
添加一条评论
Where is it located on a 2000 Tahoe limited 5.7? Thnx
这个答案有帮助吗?
得分 2
添加一条评论
replace both because i had the same problem. and got the same codes. they do the same. because pcm don't know with one.
这个答案有帮助吗?
得分 0
添加一条评论
Go to the local
Chevy dealers parts counter.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
得分 -1
1条评论:
- Jeez what a great answer. They should shut down the site with answers like this. WHY did you even bother?
完成的
添加一条评论
添加你的答案
eileen vanisi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 29
总计 30,479
