跳转到主内容
加入维修社区 - 创建账户
机型 A1347,配备 2.4 或 2.66 GHz Core 2 Duo 处理器。
2010 MacMini Thermal Sensor location
I have the above-noted Mac Mini. All works well except the fan runs at 5000+ RPM all the time
I suspect the thermal sensor is either bad or connected incorrectly to the system board.
My questions is: Which of the 2 possible locations on the logic board are used if there is only a single HD in the system? Or, does it even matter?
I bought this unit used, and there were other minor details about it that make me think whoever added/ replaced the HD was not careful in reassembly of the Mini - which is why I wonder about the possible misplaced sensor.
Thanks in advance!
Update (01/25/2016)
The images would have made more sense, if, when I opened up the Mini, there had been 2 thermal sensors connected. As it was, there was only one and it was connected to the left connector (farthest from the RAM slots. )
I moved it over to the right slot and it's settled right down,
Thanks for the quick reply
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Thank you so much -- this solved my fan issue!!!
完成的
ditto. fixed my fan issue too. But do search for the common issue of people ripping apart that connector. Very easy to do and need to know the trick to avoid damage.
完成的
添加一条评论
1个答案
已选择的解决方案
See step #13 of this guide: Mac mini 2010中期硬盘更换
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
tjod 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 32
总计 5,641
