跳转到主内容
加入维修社区 - 创建账户
Lenovo Zuk Z1 是一款联想在 2015 年 9 月发布的 Android 智能手机。
How to replace the front LCD panel?
I need help on the substitution of the front panel (cracked) of my Zuk Z1 by Lenovo.Have you got any suggests for the disassembly?Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
I have the same problem.
由完成的
where did you order the new screen?
由完成的
I do have the same problem, could you help where to order for the new screen?
由完成的
Alibaba or part4repair
由完成的
Hi, you can find the disassembly process on youtube. You need to remove back cover, sim slot, battery, antenna cover, upper mother board, lower circuitry and be careful with connectors and cables. The display is quite tricky since you need to heat up from the front detach it from the frame and use some double side adhesive to glue the new one to the frame. You can find replacement displays on ebay.
Hope this helps
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Here is a link which shows how to dis-assemble a ZUK Z1.
Hopefully it is of some help to you.
https://www.youtube.com/watch?v=tNX6otkl...
这个答案有帮助吗?
得分 4
2条评论:
Link broken. Please update!
由完成的
@c0fynian0 here is the Zuk Z1 disassembly
由完成的
添加一条评论
添加你的答案
Enrico Trevisani 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 35
总计 7,998
