跳转到主内容
The Mazda Millenia is an executive car produced by Mazda, a Japanese automaker, between 1993 and 2002.
13 个问题 查看全部
I would like to know if there is a resistor
2001 mazda millenia. I am not getting power to my fuel pump. I have checked the relay, even bought a new one. I would like to know if there is a resistor. dealer says that there is not one. online says there is one... where is it located?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
albert enstin there is no separate resistor other than the one in the relay. Since you already replaced the relayI'd suggest you check to ensure that you have power to the fuel pump relay.
Fuel Pump Resistor and relay (Speed)
Inspection
1. Disconnect the fuel pump resistor and relay connector. Measure the resistance between terminals A and B by using an ohmmeter
Specification:0.38-0.42 ohm
2. If not as specified, replace the fuel pump resistor and relay (speed).
这个答案有帮助吗?
得分 1
2条评论:
Hi,
Hey OT03 I'm confused by your answer given that you have posted this for a same year range model fuel pump fuse location
完成的
jayeff, you are absolutely right. Reading the original answered, I confused myself. It should have read that there is no separate resistor. Hope the edit clarified it a bit. Thanks jayeff.
完成的
添加一条评论
添加你的答案
albert enstin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 452
