跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 13-7352 于 2014 年 8 月首次推出。它是 7000 系列笔记本电脑。
screen very dim after windows 10 update
laptop was working great up until windows 10 update.......screen very dim......need to point light to screen to see anything
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
Have you tried installing the latest Win10 video driver for your laptop. Maybe try 'safe mode' to see if the screen is more visible to allow you to update driver or try an external monitor and see if it allows you to see to update.
Here is a link.
http://www.dell.com/support/home/us/en/0...
这个答案有帮助吗?
得分 2
添加一条评论
Sounds like the physical LCD has gone bad or the dimmer has been turned down all the way. I'm leaning more towards the LCD but check your screen brightness settings first. If your brightness settings are turned up all of the way and the issue is still there then it is the physical LCD. If it is the physical LCD then Windows 10 didn't cause the problem, that was just coincidence.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,643
