How do I stick volume buttons to the bracket
I tore the power/volume cable while replacing the screen. I purchased the new cable and finished disassembly. While trying to reassemble, I peeled the protective covering off of the cable beneath the volume and lock components. When I press them to the bracket, the buttons and switch (the last step/first step in reassembly) will not stick. They pop off when trying to stick the next one on. Is there another adhesive I can apply to get them to stick that will not damage the cable?
1条评论
When using super glue, , I use a needle to stick down the tube of superglue and that way you only transfer a tiny amount of glue from the end of needle onto your cables and it keeps from getting too much glue from spreading to other parts of the cable.
由 Chelle Cancain 完成的
