跳转到主内容
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
Why does the tub not spin with a full load?
The tub will spin automatically during the spin cycle with a light load, but if a full/heavy load, like when washing towels, the tub will not spin by itself. Will start to spin if open the lid and give the tub a "push" to start it spinning.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@oldturkey03:Thank you very much. First, I didn't realize my washer was a direct drive. Second, it really looks like this will be the solution to my problem. The clutch doesn't look like a very expensive part so not expensive like replacing a motor, etc. I will pursue this solution. Thanks also for a VERY quick response.
完成的
@ghkroupa cost for the clutch is anywhere between $20-$40USD and pretty straight forward repair. Only word of advice, the output shaft is just sitting in the transmission and can easily pulled out through the transmission cover. This will ruin the oil seal and it's a bit of a PITA to replace it. Most likely you will not have to exert any force on that unless you decide to replace the clutch housing itself as well. Best of luck to you
完成的
添加一条评论
1个答案
已选择的解决方案
@ghkroupa this behavior could be caused by a bad clutch. Take a look at this guide. different model but same idea. Let us know what you find.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
George Kroupa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 5,805
