简介
Here is a Kenmore 400 model 11029422801 with a clutch that was slipping. The washer went through all the programs but left the laundry soaking wet after the spin cycle. It sounded like it was spinning, but when we checked the drum while spinning, we noticed that it was not achieving full spinning speed. This was most evident on heavy loads.
你所需要的
Kenmore 400 washer that has difficulty spinning. It runs through the cycle but does not spin properly.
Open the lid
Remove cap from the agitator by using a flat tip screwdriver or similar.
11等其他人完成本指南。
15条评论
Would this repair fix a 80 series Kenmore washer with same problem of no high-speed spinning
Possibly but it depends on what is going on with it. This one spun just sluggish and not „forcefull“ enough. It pretty much stopped spinning with a full load because of the weak clutch
How much do it cost to repair it
The complete repair kit was somewhere between USD $30-$40
I'm a jack of all if I can get it out I can rebuild it im a maintenance man at chicken proscenium plant we got to fixs all of it
