跳转到主内容
The Lenovo G570 is a 15-inch laptop announced in January 2011.
Hinge is Missing a Screw
The left hinge connecting the screen with the base is missing a connector (screw?) and opening and/or closing the screen pries up the top of the keyboard. There is a hole in the bottom of the base under the hinge which is missing whatever it was that made the connection between the base/keyboard and the screen. I need to know what it is that is missing and where I can find a replacement part. Thanks!.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Hi,
Here is a link to the service manual. Scroll to p.57, I think that shows the screws you are talking about.
https://download.lenovo.com/consumer/mob...
这个答案有帮助吗?
得分 1
3条评论:
Thanks for the tip. The location I am missing a part for is best seen on p.70 of the Hardware Maintenance Manual referenced. It appears to be their part #6 on that page and called a Kensington Slot. Can you please tell me what it is and how I can find a replacement? I sure appreciate your help!
完成的
Hi,
A Kensington Security slot allows you, with the appropriate attachment, to chain your laptop to a desk for example. It is a security feature on the better laptops.
Here is another link which may explain better.
https://www.youtube.com/watch?v=LO8ydKhH...
Somehow I don't think, in your case, that this is the something that is missing. The Kensington lock plugs into the slot. Never had a laptop with one myself, but I don't think that it would have much to do with your problem. I think the slot is just that , a slot if you wish to utilize it or not is up to you.
完成的
Hi
Found this link, which states how to fix your problem. Apparently is it a common one with your model laptop as well as some others. https://www.reddit.com/r/techsupportmacg...
完成的
添加一条评论
It is a well known design flaw. Do a bit of Google searching, even Lenovo's own forums have several threads on it. Mine was replaced after 30 months, the replacement has just failed after 22 months. This product does not last.
这个答案有帮助吗?
得分 1
添加一条评论
Hi there. i know this is answered a few times, but i spent the time, and found the figure for the back panel screws. here you go.
http://tinypic.com/r/24px9ol/9
这个答案有帮助吗?
得分 1
1条评论:
Thank you!!!!
完成的
添加一条评论
I called Lenovo tech support, which gave me the part number for the screw. I was transferred to parts, where I was told it was out of stock for at least 3 more weeks, and it'd cost $11.98. For *one* tiny screw. That probably fell out when I sent it in for repair last year and it was 4 months before they sent it back. Once I'm sure the correct screw is included in a stupid bulk bag for $10 and arrive in 4 days, I'll get it. Then, I'll never buy a Levono laptop again!!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephen Sattler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 3,978
