跳转到主内容
Identifiable by the model number S7562, the Galaxy S Duos is a dual sim card smartphone made by Samsung.
The phone is not charging
my phone is not charging even when i am using the new battery and how to resolve it.. i think the charging port is damaged and please help me is repairing that.....kindly send me the repairing formats .....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@logesam the USB port is soldered to the logic board.
To remove it you will have to disassemble your phone. Use this document Samsung-GT-S7562.pdf to disassemble your phone. After that you will have to unsolder the port, find a replacement and then resolder the new port.
这个答案有帮助吗?
得分 2
1条评论:
Thanks Oldturkey, that is one I had not ran across before and wasn't terribly sure if it was soldered on or not. Being that it isn't that common of a phone, I wouldn't have imagined a replacement port be too easy to find, then a quick Google search proved me wrong. Anywhere from $2-5 and plenty of them.
完成的
添加一条评论
Hi Logesam, I apologize for not being too familiar with that device in particular. It appears to be very similar to the Galaxy S3 though. When you open it up is the charging port soldered on the main board, or is it a separate component attached by a ribbon cable? If it is truly similar to the S3, it may be easier to repair than you think.
这个答案有帮助吗?
得分 1
2条评论:
My device name is Samsung Galaxy S Duos S7562
完成的
Right, yes I see that from your original post. Since I have not worked on that exact device personally, I'm trying to do some probing questions to see how I can assist. Have you opened the device up yet? Can you tell if the port is soldered on the main board or is a separate component attached by a ribbon cable?
完成的
添加一条评论
添加你的答案
LOGESAM 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 6,610
