跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Why won't battery hold a charge for long?
Battery charges up to 100% but charge doesn't last long.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
There could be multiple reasons why it don't hold charge. It could be the outlet, the adapter or the charging port on your iPhone. 1st try using a different outlet. If that don't work, then get a new charger and see if that works. If nothing else works, then maybe try not using the phone for a long period of time and see if that works. Does it not hold charge when your on the phone or does it do it whenever?
这个答案有帮助吗?
得分 1
添加一条评论
ybc, if your battery charges but does not hold a charge then you have a failed battery. If it is the original battery in your phone, it lasted a pretty good while but has most certainly come to the end of its life. You can get the battery from here and use this guide to replace it
Replace that dying battery or carry an extra for backup power! 3.7 V, 5.3 Whr, 1430 mAh. Compatible with all iPhone 4S models.图片
产品
iPhone 4S Battery
$18.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ybc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,128
