跳转到主内容
The Huawei Mate 7 (also called the Huawei Ascend Mate 7) is an Android smartphone produced by Huawei, released in October 2014. Models MT7-TL00, MT7-L09, MT7-TL10, MT7-CL00.
MT7-L09 lcd replacement no working
Hello,
today i wanted to repair an lcd screen on the phone huawei mate 7 model L-09. When i tested the new lcd screen, it only shows the logo and then went black. When i recconect the old one(lcd with broken glass) it goes normally in the menu. I ordered a normal lcd from ebay and now i am wondering if there is a difference between models L-10 lcd and L-09?
Does any one has any idea of why is that happening?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
5个答案
It is best to use original part, try returning it saying it didn't work then get the right one. Should work fine After that.
这个答案有帮助吗?
得分 0
3条评论:
Please let us ignorants know where MT7-L09 replcement screen sells.
完成的
Where can I get the original replacement part, ?
完成的
You can buy any replacement parts for this phone at http://www.etradesupply.com/huawei-ascen...
完成的
添加一条评论
L-10 lcd is the model Huawei sale in china
L-09 is for Europe.
这个答案有帮助吗?
得分 0
1条评论:
But why noone on ebay sell the TL-09 model lcd??
完成的
添加一条评论
I have also a huawei mate 7 model L-09 and i have broken the screen.
It s very difficult to find this screen.
There is a lot of screen for TL10.
Do you have repear your phone ?
Raspigaous
这个答案有帮助吗?
得分 0
添加一条评论
Hello.
I was able to get my phome working using an LCD screen from the MT7-TL1 model.
You need to use the LCD controller chip number on the defective screen to find one that would work.
The chip under the green sticker in the lower left corner of the broken screen said 1 on mine. I had bought the TL10 LCD also but that had a 2 on it and didnt work.
Once I used an LCD screen with a 1 on the controller chip, it worked flawlessly.
I used ebay for mine. Cost about 80$ US max because I got the frame also. It's about 60$ without the frame. Free shipping.
Hope I helped you guys out.
这个答案有帮助吗?
得分 0
2条评论:
Hi there!
Tnx so much Im sitting with the same problem... Broken L09, can only find TL10 screens for sale... Can anyone confirm 'Emm's' solution with the number at bottom left worked? Alternative solutions?
完成的
That "chip in a corner" is Synaptics touch controller and has nothing to do with display working or not since it only handels touch function. My guess is if replacement lcd isn't working it is DOA and one should request another or problem isn't in display but in display controller or "graphic card" if you wish. Buying cheapest replacement isn't allways best move, opt for one with good buyer feedback.
完成的
添加一条评论
Hi infoservis112! Did you ever get it to work using above answers?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
infoservis112 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 6,423
