跳转到主内容
加入维修社区 - 创建账户
发布于 2004 年 5 月。可通过 ThinkPad T40 系列的型号 T42 进行识别。
Will not switch on?
No charge lamp lit prior to switch on. No lamps illuminate, no noise, nothing happens when "on" switch depressed. Same occurs with battery removed and ac supply (which is correct) is plugged in. This looks pretty terminal yes? Grateful for any advice, thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
I don't think I would say terminal yet. I am including a link for the service manual for your computer--maybe it will show you a way to save it. Ralph
http://download.lenovo.com/ibmdl/pub/pc/...
这个答案有帮助吗?
得分 2
4条评论:
Thanks Ralph, I've checked out the link, followed the procedures and looks like the system board is defective. I've found a refurbished board on e-bay at £40 so it's decision time. I have an electrical background but I've never dismatled and fitted a laptop motherboard. The step by step guide from this site makes it sound doable providing I take care and take the precautions listed in the link. I think it might be worth seeing if I can remove the old one 1st. What do you think? Thanks again, Mark.
由完成的
由完成的
+. I say go for it Mark, what do u have to lose?
由完成的
Certainly try the removal of the faulty board first---just be sure to identify and save the hardware. Good luck Ralph
由完成的
添加一条评论
Check the status of the internal button BIOS battery. Also make sure that at least the power light is on when the power adapter is plugged in.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mark 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 1,788
