跳转到主内容
加入维修社区 - 创建账户
Car Does not Start
My car doesn't start wen I try to crank it is a 2005 Ford focus what should I do
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Give us more information
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Does the motor crank when you try to start it? if it does not then you have a problem with your starter or battery. If it does then your problem could be fuel related turn the key to on but dont crank the engine ...listen out the door towards the back of the car do you here a buzz or humm if not you have a fuel pump issue. if you hear the hum then you have an ignition problem and if this is the problem start by checking for an engine code. You need 3 things to start your car 1 fuel 2 air and 3spark your missing one so investigate and get back to us we can help with more info from you
这个答案有帮助吗?
得分 4
3条评论:
Good example of how to answer a poor question ;-)
由完成的 分享
Thanks for the comment
由完成的 分享
Ive replaced alternator spark plus fuel sensor battery coil pack and my 2007 ford focus still will not start i dont understand what it could be
由完成的 分享
添加一条评论
添加你的答案
limonez36 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 10,861
