跳转到主内容
加入维修社区 - 创建账户
Toshiba Tecra M2 型号曾因其轻量化设计和蓝牙功能在商务领域广受欢迎。
How do I remove the BIOS password?
Hello! I bought about 30 Toshiba Tecra M2s from a recycler, and while they are nice little machines, a few of them have BIOS passwords in place that prevent them from booting at all. They simply ask for a password when you power them on. BIOS password removal tools do not work because the password prompt appears before the machine even attempts to boot from CD, etc. I've tried removing the battery for 5 minutes, and several other forms of magic suggested by random pages when I Googled the issue. Nothing worked. Unfortunately I'm not very experienced with Toshibas and am therefore pretty clueless about this. Anyone have any ideas? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
+ for the question
完成的
添加一条评论
8个答案
已选择的解决方案
Hi, I don't know if you've seen this link but it looks like it may help you. Also it seems if you take them to a retailer with proof of purchase they will reset them for you. Good luck Ralph
http://jevarax.wordpress.com/2008/08/08/...
这个答案有帮助吗?
得分 5
2条评论:
Thanks Ralph! I saw that link, and it's good information, but unfortunately it's for really old laptops. M2s are old, but not quite that old. :-)
完成的
Hi Ralph, can you please help me remove Bios Password on a Toshiba dynabook SS Rx2?
完成的
添加一条评论
There are 4 methods of removing BIOS password:
  • Remove Battery
  • Change Jumper Settings
  • BIOS Password Recovery Software
  • BIOS Backdoor Password
This article has described the methods above:
http://www.top-password.com/knowledge/re...
这个答案有帮助吗?
得分 1
添加一条评论
not all laptops remove the cmos will work thats very old 90s solution
the bios password is located on the main bios IC like eeeprom named winbond or MX in toshiba devices
you must remove it with hot air then flash the IC with a programmer with new bios file
is not easy as i see in the comments
这个答案有帮助吗?
得分 1
添加一条评论
Short circuit the system clock battery (preferably an old battery, not a fresh Lithium Battery to be shortcircuited ) fitted in the motherboard and then reboot your machin
这个答案有帮助吗?
得分 0
添加一条评论
I also try to find some other solutions because I also lost my BIOS password, and I think this article about how to reset or remove BIOS password will be of great help:
http://www.recoverlostpassword.com/artic...
这个答案有帮助吗?
得分 0
添加一条评论
Try removing the CMOS/BIOS battery or see if there is a jumper on your motherboard that will reset the password.
这个答案有帮助吗?
得分 0
添加一条评论
remove the jumper on the board
这个答案有帮助吗?
得分 0
添加一条评论
As far as I know about BIOS, there is 2 forms of BIOS passwords. The forms are desktop and laptop/notebook.
Desktop BIOS passwords are easy to bypass by moving the jumpers.
Laptop BIOS passwords are way more difficult to bypass as they are stored on the EEPROM chip which is soldered to the motherboard.
If you don't know the BIOS password, you need to either talk to the guy who previously owned them or put new motherboards in them to get past the BIOS password.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rdklinc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 29,386
