跳转到主内容
加入维修社区 - 创建账户
Lenovo Y50-70 Touch 发布于 2014 年 8 月,属于联想 Y 系列笔记本电脑。Y50-70 Touch 配备了独立显卡和 15.6 英寸触摸屏,专为游戏设计。
My Laptop Screen is sometimes flashing
My Laptop Screen is sometimes an instantaneous flash once every two hours.
i want to solve this problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I just replace the screen cable on a y50 it was pinched by the hinge and would cause the screen to flicker randomly the odd thing was that flexing the hinge never made the flicker happen it only ever happened when the laptop was being typed on .
Hope this helps
这个答案有帮助吗?
得分 5
1条评论:
when I unplug the monitor connector from the hub and reconnect it again ,Flashing stops.
but i usually do this when repeated again. Any advise ?
完成的
添加一条评论
Do you have a white stripes when screen flash? If not - problem is in a display and display cable. If flashes with a white stripes - problem with gpu.
这个答案有帮助吗?
得分 1
2条评论:
Could you develop ?
完成的
White stripes flashing shows wrong GPU calculations or broken video memory. If screen flash without white stripes in this one model means that cable or LCD is wrong. Lenovo knows about this issue.
完成的
添加一条评论
添加你的答案
ahmedhagag352 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 15
总计 1,963
