跳转到主内容
加入维修社区 - 创建账户
LG G4 于 2015 年 6 月初在美国发布,它一如既往地专注于高端规格和精致的时尚感,使其在高端智能手机市场中脱颖而出。根据运营商销售或无锁版(美国或国际版),该手机的每个版本都有不同的型号。众所周知,部分 LG G4 存在无限重启问题。
LG G4 Security error #11
Is there any way to fix this? I know there is a factory image for tmobile but how do I go about flashing it when the phone won't go to any screen other than the LG security error logo.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
My Suggestion is to try and get it to go into Recovery Mode, This can be done by pressing the Volume Down Button and the Power Button, Once the LG logo appears when the device turns on then keep holding the volume button but release the power button then press and hold the power button again. This should get you to a Factory Data Reset let me know if this helps. Thanks
这个答案有帮助吗?
得分 2
6条评论:
I had the same issue, but it went to the error message before i could get it into recovery mode
由完成的
I have the same error but could get to recovery ok using the above method. It's all timing to get into recovery. I have not fixed this yet but there is a return to stock method I am going to try. You boot the phone to fastboot and flash stock image.
Try this link: http://forum.xda-developers.com/g4/gener...
That's what I'm trying.
由完成的
I have the same problem. whenever I touch the security logo it only revert back to the screen with message: unfortunately, the process com.android.settings has stopped. This is making the phone very slow and not able to even uninstall unwanted installations.
由完成的
Got as far as the dancing android then it kicked back to security message.
由完成的
@bradleygustin it didn't work from me
由完成的
显示更多的1条评论
添加一条评论
As posted in a reply above, if you go to the XDA link here: http://forum.xda-developers.com/g4/gener... and follow the instructions to download and flash stock firmware image, you will be back up and running with a new out of the box condition.
There is also a Puerto Rico version you can flash that has no AT&T bloatware on it but does not support VOLTE. Thinking really hard about doing that as the bloatware is rather ridiculous.
Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jeremy Schwartz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 28
总计 28,202
