跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad T430 的指南和维修信息,这是一款由联想推出的 14 英寸商务笔记本电脑。
Power button LED Blinks when I press power button.
Lenovo T430. Tried following steps, No luck. Refer to my Video here.
  • Try charging the Battery to Full
  • Remove Battery and tried booting it with Power directly.
  • Changed the Keyboard.
  • Removed the Bios Battery and tried to switch on.
  • Removed the RAM and tried to switch On.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
Is there a pattern to the blinking?
完成的
No It just lits up and turns off. I dont think it is a pattern.
完成的
is there one or two sticks of ram
完成的
Do you get any fan sounds? Do you hear the hard drive spin up at all
完成的
yes i hear a fan sound, it comes and goes off (the sound)
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
Try removing one stick of ram if you have two and test one stick at a time in each of the two ram slots. Then test the second stick of ram in both ram slots this will tell you if you have bad ram or a bad ram slot. if it still doesn't work you need to consider getting out a multi meter and tearing open your computer and testing the circuit board starting at the power outlet and working into the board
这个答案有帮助吗?
得分 3
2条评论:
I tried the RAM swaps , no change. Also Fan wont turn on. I am not familiar with electronic circuits.
完成的
Even now 2021 i have that problem on my Lenovo All-in-One Computer IdeaCentre 300-23ISU (F0BY0041US) Intel Core i3 6th Gen 6100U (2.30 GHz) 8 GB DDR4 1 TB HDD 23" Touchscreen Windows 10 PRO 64-Bit
完成的
添加一条评论
I have a T430 with the same issue. LEDs (power Fn F3 ) are blinks one but the laptop does not turn on.
I triedtoclean the connections, remove the batteries....no change.
Once i removed the RAM and the unit booted up.
So the issue is the following : it works with no RAM, but it does not work with installed RAM.
The problem is the same with the old and a brand new RAM also.
Any idea?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ksenthilbeit 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 31,278
