跳转到主内容
The Asus MeMO Pad 7 ME170C is a touch screen tablet manufactured by Microsoft and released in August of 2014. It has a screen resolution of 1280 x 800. Identified by model number K017.
USB charging port got broken, need to replace.
I have one ASUS MeMO Pad 7 – ME170CX ; 7-inch, 16GB. Charging USB port got broken. Its needs to be replace. Can any one tell me how to fix this with details procedure. Or if any one can fix it for me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
If it's any help, I googled Asus Memo Pad 7 charging port, and the replacement appeared for purchase.
完成的
添加一条评论
2个答案
最有帮助的答案
Hi, as of right now we do not have a guide on how to repair the USB port. Hopefully, in the future there will be a guide for this. If you feel confident and have done research on the device, you can use the first step of any of our guides to open the device exposing all the components and see what you can do to fix the USB port. I advise extreme caution if you do decide to open the device as there are many variables to consider. Those cautions are noted in the first step of all our guides. I hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
This requires hot air soldering experience, and this particular pad is complicated by the fact the camera is right next to the port which could cause issues on repair.
I have so far not been able to source the parts for this repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tushar De 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,284
