跳转到主内容
加入维修社区 - 创建账户
Stream 7 是惠普(Hewlett-Packard)于 2014 年 9 月发布的一款紧凑型多功能平板电脑。
Screen is un-responsive to touch
How should I approach getting my screen to work again? It will not reach to my finger when trying to use it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
screen is blue and says it needs to be hooked up for repair. Have plugged it into my laptop but with no change.
完成的
添加一条评论
2个答案
If the screen does not work make sure that the device is charged and also clean the screen of any debris or oils that might be inhibiting the screen from reaching to your finger. If this still does not work try to power down and/or reboot the device. If all else fails it is likely that the screen has gone bad and may need replaced. If the device has been dropped or has a cracked screen this could be a likely problem.
这个答案有帮助吗?
得分 0
添加一条评论
The screen is blue and says it needs a repair and is not hooked up to the required device. what is the required device?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alek Minkis 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 24
总计 801
