跳转到主内容
The PowerShot S110 has a 12.1 Megapixel High-Sensitivity CMOS sensor and DIGIC 5 Image Processor, 12-bit multi aspect RAW+JPEG, 24mm Wide-Angle, f/2.0 lens with 5x Optical Zoom and a sleek pocket-sized body.
Is it possible to replace the flash light?
Because the flash light is not working I want to replace it but I don't know if it is possible. I can't find anything about replacing the flash light and I don't wanna open the camera without knowing it. I can't find a replacement item either.
If anybody knows anything about this, please let me know, thanks a lot.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Yes, it is possible.
You have to exchange the "Canon PowerShot S110 FLASH ASS'Y Replacement Repair Part".
This is hard to find but i got it on http://www.ebay.com/itm/Canon-PowerShot-...
Use the dis-assembly instruction for the display and remove further the copper foil under the display to find 2 further screws on the camera backside, remove these and also one screw on the assy frontside. Carefully disconnect the foil plug of the build-in assy and you can easily do a drop-in replacement of the assy.
My camera is again working.
Never manually push-in the flash of the camera. This will destroy the camera flash assy.
Good luck ;) !!
这个答案有帮助吗?
得分 2
添加一条评论
i also have this problem with the s100..flash will not fire..the flash raises up..the program is set on flash..however, will not fire? have no idea why? if someone can give me advice to fix the flash..please give to correct my problem...thank you..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
justtrying 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 1,815
