跳转到主内容
The HP All-in-One desktop personal computer released in the Summer of 2013. This 20" touchscreen is an ideal family home computer that can function as both a desktop and a mobile computer.
2 个问题 查看全部
My headphones don't work when I plug it into the jack?
My headphones work fine when I'm using them on my phone but for some reason they don't work when I plug it into my computer. How do I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 29
4条评论
i have the same problem too and i dont no what to do
完成的
I plugged the headphones into my computer and then restarted it. They worked after that.
完成的
im trying to do a meeting and i cant hear whats happening
and when im doing code.org for fun the music aint working
完成的
my work headphone doesn’t work when i plugged in
完成的
添加一条评论
6个答案
已选择的解决方案
Alyssa Kristedja. Make sure that the drivers for your audio card are properly installed. Also, and I know this sounds stupid, but make sure that your headphones are properly plugged in to the headphone jack, not the mic etc. If that still won't work, check the bios to make sure that your audio card is properly initialized.
这个答案有帮助吗?
得分 7
3条评论:
bruh bruh im still 9
完成的
And im just 10 but what do u mean by not the mic
完成的
and I'm HeadPhones do work but we plugging in the sound. won't work to the headphones.
完成的
添加一条评论
最有帮助的答案
Assuming your headphones do in fact work, it might be that the device isn't recognizing them or just overrides them. If this is the case then you can manually connect and set your headphones as default through these steps..
For Windows 8 and 10 move your mouse to the top right of your screen and then straight down to bring up the charms sidebar.
a. Click settings
b. Click Control Panel.
c. Go to Hardware and Sound.
d. Click on Sound.
e. Right click your headphones in the pop-up window
f. Click connect
Hopefully this will set your headphones as the primary playback device. If this fails see the troubleshooting page mentioned above.
这个答案有帮助吗?
得分 8
3条评论:
What if you dont see your headphones in that window???
完成的
i dont see the word connect as on option, so i just clicked ok but it still didn't work.
完成的
bro thank you so much
I was having so much trouble trying to figure out what happened
so this really saved me
完成的
添加一条评论
FOR MACBOOK AIR-
Im so happy that i figured this out
It might not be 100% accurate
1) Go to settings
2) Click Sound
3) Click output
4)plug your earbuds in
5) Click headphone port
6) slide the balance bar around, and it should work
(if you take your headphones out and it doesn’t make noise, slide the bar around again)
Hope this helped
这个答案有帮助吗?
得分 4
1条评论:
This also works for Microsoft. Instead of clicking on sound, type in the search bar "sound" and click on the tab that says sound settings.
完成的
添加一条评论
I have the same problem, everytime I plug in my headphones it says they aren’t plugged in, and these are brand new. Although, I tried restarting my Dell and now my headphones are working. I’m assuming you have to restart your computer every time you plug in your headphones to work, hopefully this works for you guys too
这个答案有帮助吗?
得分 3
1条评论:
yeah but how do i make it so i never have ti restart
完成的
添加一条评论
I'm having the same problem. I have a Dell laptop and so I've been taking with the reps. They gave me links to reinstall and I'm still having the same problem. The install links I got were: chip set, bios and the audio driver. I tried different headphones with no luck. I've looked online for a fix. One actually worked but it was only temporary. I'm wondering if my bluetooth devices are part of the problem even though they were never an issue before. I've never had this problem before and this one is a complete mystery. Even the reps at Dell are stumped. Their solution is to do a mail-in service.
这个答案有帮助吗?
得分 2
添加一条评论
On one phone, it didn’t work until I pushed hard on the plug and heard a click.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alyssa Kristedja 将永远感激不已
浏览统计数据:
过去 24 小时: 21
过去 7 天: 119
过去 30 天: 568
总计 144,556
