跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
wifi button greyed out on ipad air after update
Hi, i recently updated my ipad air to ios 9.1 i think and now i have a greyed out wifi button and no bluetooth, i have find my iphone turned on so i cant restore it because it needs a wifi signal to turn off find my iphone, any ideas??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Update.. restored this ipad multiple times and set it up as a new ipad but still no luck. I own a device repair shop so knew about the greyed out wifi switch issue that plagues some of the iphone 4s and know how to fix that so tried the same fix but no luck. Contacted apple support on a chat forum as the ipad is 6 months out of warranty and they wanted €330 to carry out an out of warranty repair but as soon as i mentioned that this has all the same symptoms as the 4s issue they set up a call-back from someone from the senior team that aggreed to repair/replace the ipad for free.. happy days
完成的
添加一条评论
6个答案
最有帮助的答案
I gave same problems, please help me, I have an iPad Air 2 on iOS 9.3.5
这个答案有帮助吗?
得分 1
1条评论:
I'm having the same issue, was using it at the time and all of the sudden it coudn't connect to the server. I've tried everything including a restore to factory and nothing. have you figured out a solution?
完成的
添加一条评论
I have a iPad Air 2 and same thing happened. I went into the genius bar and they refused to replace or fix the issue because it was out of warranty. They also suggested me to trade-in the iPad for a new one plus pay a couple hundred bucks! ( wtf? ) My iPad Air 2 64gb worked flawlessly before the updating to 9.3.5.
这个答案有帮助吗?
得分 1
添加一条评论
I believe you can turn off 'find my iphone' directly through the ipad: settings --> icloud --> near the bottom it'll be a slider to turn on or off find my iphone. Or at least that's the way it is in my iphone 5c
这个答案有帮助吗?
得分 0
添加一条评论
You need a wifi or data access to turn off 'find my iPhone ' and because it's a wifi only iPad and the Bluetooth doesn't work either, I put it into dfu mode and restored it that way. It seems to a hardware issue because even after the restore its the same..
这个答案有帮助吗?
得分 0
添加一条评论
Because it happened during an update i convinced apple to replace the ipad.. even though it was out of warranty.
这个答案有帮助吗?
得分 0
添加一条评论
wifi and bluetooth buttons are inactive. not working after upgradation ios software. Please say how to rectify my issue on ipad
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 11,583
