跳转到主内容
加入维修社区 - 创建账户
Huawei P8 Lite(型号:ALE-L21)于 2015 年 4 月发布,展现了简约之美。其专业摄像头让你即便在最昏暗的环境下也能拍出自然、清晰的照片。美颜模式能让自拍中的你时刻展现最佳状态。
Why my phone doesnt charge?
my phone is not charging even if its connected to charger. at first there was this weird led lights blinking then after few moments it stays at 0% not even charging. I tried different charger but still not charging. My charger is working. Help please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 21
11条评论
Sir I am also having the same problem that my mobile p8 lite doesn't charge , when I connect the charger .. the battery percentage does not increases, it stays the same .. Sir please guide me the suitable solution ... waiting for your reply ....
由完成的
hello iam using huawei p8 lite my problem is that when i connect my mobile with my laptop my mobile shows the charging but not save how to fix it .
thanks
由完成的
Huawei p8 lite not charging even after replacing the charging port,
What else can l do to fix it please
由完成的
i have huawei gr3 2017 known as huawei p8 lite 2017 or huawei honor 8 lite
with a battery problem
but after changing it does'nt increase in charging porectage
the screen is on when i put the charger
but there is no ''electrecity logo " in the battery poucentage
由完成的
use a good 3.0 mah charger or 2.5 mah charger. it works sum time 2mah or 1 mah charger was drain the battery's be cues of low amp and charging I-C temperate get hi and drain the mobile battery.
由完成的
显示更多的6条评论
添加一条评论
9个答案
已选择的解决方案
Hi,
Blinking red light indicates low battery (when phone is not connected to charge). It should turn to a steady red light when charging. Is it steady when you have connected the charger?
If not, you probably have a faulty battery or faulty charging circuit in the phone.
If so, how long have you left it on charge? Leave it on charge for 1-2 hours and see if it starts to charge.
(I suggest this because I had a android phone with a completely flat battery which initially did not respond to the charger, so with nothing to lose I left it on charge, after 1.5hrs it suddenly kicked into life and started charging and subsequently took another 3 hours to fully charge - and has been good for over 12 months now charging normally)
If it does not respond at all after you have tried the above you probably have a faulty battery or faulty charging circuit in the phone. Check your warranty details and if still valid contact the maker.
这个答案有帮助吗?
得分 14
3条评论:
This was helpful because i had the same problem
由完成的
help ful idk
由完成的
My phone not used to get charged n used to show red light instead. Also its back button not worked. I put my phone in the freezer for 2 hours n repeated this action 3 times. After a month the charging came to be normal. Also the back button not worked n I found out that it was because of the water which had entered the screen of the phone. I installed back button from play store n after few days the phones back button started working itself. Now is my phone working perfectly n it does't have any defect. But I'm sure that the back button will be not functioning if the rain hit my phone screen. I have to save it from water because it takes almost a week untill its back button gets normal. My phone is 4 yrs old n is like a friend to me. Not wanna change it.
由完成的
添加一条评论
Basically I have found the best solution to such a problem, all you have do is unplug from charge, turn on the phone, when the Huawei logo shows up on boot, plug the charger in on that stage, once turned on it mostly starts charging normally.
If unsuccessful, redo the same steps after the phone shuts down automatically. Once you get into the timing, it will work every time(as it has with mine). Even tho it is becoming an unecessary hassle.
This method works, I certify it with 100%
这个答案有帮助吗?
得分 10
7条评论:
I am not sure why this works, but it does. My phone now is a couple of years old and has only just started doing this...I guess time for a new phone
由完成的
Hi @Alun Evans,
It may be time for a new battery. Even rechargeable batteries have a life span. If you feel so inclined here is a link that shows how to replace the battery. It also has details of which battery to buy. This should also be printed on the battery.
All this is of course if you have a Huawei P8 Lite!
https://www.youtube.com/watch?v=mSTMIQ-w...
由完成的
when I plug my huawei p8 lite for charge, it show me its charging, but slowly it starts to loose charge. what should I do??
由完成的
Hi @ imtiyaz nabil,
Have you tried a different compatible charger?
Are you charging it and using it at the same time when this happens? If so try fully charging it with the phone off and then see how long the battery lasts.
What do you mean that it starts to lose its' charge? Do you mean that this happens when it is charging?
How old is the phone?
Even rechargeable batteries have a life span. if it is 2 years or more then perhaps you should consider getting a new battery installed.
由完成的
Mine doesn't stay long if I charge it during the night the next day it first stay upto 2 hours what can be the problem? This is the third day using it it's brand new Huawei p8
由完成的
显示更多的2条评论
添加一条评论
Hi folks,
I had the same “blinking red light during charging” symptoms on my Huawei P8 Lite with a completely flat (0%) battery. I guess this happens because Android requires a minimum level of power (2-4%, below which the phone automatically turns off) in order to control the charging process. What I’ve tried and helped was leaving the phone on charger for cca. 10 mins and after that I performed hard reset (pressing and holding Volume UP + Power keys simultaneously - the method may vary for other phones), just like when you want to wipe cache data. And voila, the phone started to boot and charge normally.
这个答案有帮助吗?
得分 1
1条评论:
Brilliant I bought an huawei phone from a repair shop!! after i jumped in a hottub pissedup and forgetting my phone was in my pocket, I tried to have it fixed but it was unfixable!! So I bought another streight there and then, got it home and it wouldn't charge. Tried everything and the hard reset was the last thing I tried and it worked I had a feeling it was because the phone was in there for a few months and needed a good kick to start the charging process,.
由完成的
添加一条评论
Unplug the charger 'cube' from the receptacle and plug it back in to a known good outlet. Simple as that (this is what worked for me). Went from not charging and displaying a low battery symbol on the display when I pressed the on button to charging as soon as I plugged the 'brick' back in. East fix!
这个答案有帮助吗?
得分 0
添加一条评论
try a charger with a lower ampier output rating. this will result in a slow charge.
这个答案有帮助吗?
得分 0
添加一条评论
I find the real problem. And I fix it too. It's was the cable inside the phone. Was not insert properly. Me sooooo happy I find it and fix it!
这个答案有帮助吗?
得分 0
1条评论:
Which cable?
由完成的
添加一条评论
I had the Same problem. the problem was on the usb port of the phone’s board. broken pins and port. check the usb port of the phone.
这个答案有帮助吗?
得分 0
添加一条评论
My phone has found a charging problem. From a week now but 2 times it was charged when I froze the phone in could n then put it in charge. Plz freez it for 15-30 min not more. But now it gets charge very slowly n consumes charge when I use it while charging. But I know the phone is used almost 4 yrs now so I ordered a budget phone 'd come soon. Still I won't through it away but watch utube instead of using the new phone. Hope it'll help somehow…
这个答案有帮助吗?
得分 0
添加一条评论
I turn off my Huawei and keep it,after a few months ago,when I turn on ,it won't turn on. when plug in charger,red light flashing to fast than slow,but half day I keep in charger,also same thing the red light flashing
这个答案有帮助吗?
得分 0
1条评论:
My phone comes on but does not want to work further please help me
由完成的
添加一条评论
添加你的答案
dennisloty 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 47
总计 165,567
