跳转到主内容
加入维修社区 - 创建账户
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
iPhone can't turn on after replacing battery
See a few weeks ago, my cousin gave me his Iphone 5 hoping that I could fix it. He apparently dropped it in water and cant turn it on. So I put it inside a container with rice for a few days and when I tested it, it worked... for a few minuites before it died and I couldnt do anything. So I bought a battery from ebay and replaced it. I double checked all the connections and charged it. A few hours later...I checked and it still wont turn on. So any ideas on how to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Daaamn. You know how to disassembly phone, but after phone get water damaged You put him in to rise ?
完成的
Um... well if it worked with my Ipod its should work again
完成的
添加一条评论
3个答案
已选择的解决方案
Well, you could try the dock connector. Before you go for thebU2IC
iPhone 5 尾插更换
iPhone 5 尾插更换
这个答案有帮助吗?
得分 1
2条评论:
Um I charged it and it became really hot any other ideas?
完成的
So it did come back on? After what?
完成的
添加一条评论
Corrosion.
You only way to MAYBE fix this, it is by using isopropyl alcohol on corrosion on motherboard.
这个答案有帮助吗?
得分 1
添加一条评论
Fred Lee, "I charged it and it became really hot " your rice obviously did not work. Heat = short circuit. Next time skip the rice. It will not prevent corrosion nor will it fix the phone, it is a misleading myth. totally agree on this with Phonetech93 on this one. The very first thing you want to do is to not try to restart the phone. This may further damage your phone. You also do not want to try to charge it any further. The next thing to do is to clean it. Disassemble your phone using these guides. Once it is disassembled remove the EMI shields from the logic board. After that you do need to clean it properly. You will need high grade isopropyl alcohol and a soft brush. Use this guide to see how to clean it. Even so it was written for a 3G all the points are still pertinent to your phone. While you are cleaning it, check for any broken, missing or burned looking components. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. Water damage is the hardest to diagnose since virtually any part may have short circuited.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fred Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 177
