跳转到主内容
加入维修社区 - 创建账户
Apple Magic Trackpad 维修指南。于 2010 年发布。
Magic Trackpad keeps losing bluetooth connection.
My apple trackpad keeps losing its connection to my Mac mini. This just started happening. The trackpad will be connected and than not and than connected and than not. I have check the battery 97%. I can see it in the blue tooth screen when it is connected and not. I have not had the same trouble with my apple blue tooth keyboard.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
You may want to make sure there is nothing interfering with the signal. Try moving the PC to a different area. Also make sure there are no other computers that are trying to connect to the keyboard and/or mouse.
这个答案有帮助吗?
得分 0
添加一条评论
You can buy and use a Bluetooth adapter. The Belkin Mini BluetoothV4.0 USB Adapter is described compatible with Mac and it is quite cheap.
这个答案有帮助吗?
得分 -2
1条评论:
Why would you suggest a Bluetooth adapter if the OP has no problems with the Bluetooth Keyboard? How is that going to fix anything related to the trackpad?
完成的
添加一条评论
添加你的答案
panson12 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 3,424
