跳转到主内容
The Canon EOS 60D is a 18 MP DSLR (digital single-lens reflex) camera with an articulating LCD screen. The camera was released August 2010 and is identified by the EOS 60D printed on the front of the camera.
HELP! Error Code 70
I keep receiving an error 70 code when I try taking photos. I turned the camera off and back on, but after several photos the error showed up again. Does anyone know how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
I get the Err 70 code to and can't do any thing else at all and after about a minute the camera shuts off. any help would be nice thanks
完成的
添加一条评论
6个答案
最有帮助的答案
If the automatic sensor cleaning is enabled, it causes an error 70.
That is, the automation solution is put off.
But I do not know what is the reason behind it.
这个答案有帮助吗?
得分 2
1条评论:
thanks seems to have solved my problem "THANK YOU"
完成的
添加一条评论
This is a memory card read/write error. First try to format the memory card. If the error continues after formatting (or the camera won't let you format the card), try a different memory card. If the error continues with a new card then you probably have an issue with the camera itself. Contact Canon for service. I hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
Hey everyone.
My error 70 let me shoot in auto, CA, C1, C2 and C3 on my Canon 7d mark I.
After realizing I need to somehow update my firmware and that you cant update firmware unless in settings P, Tv, Av, M or B Ifound that if I set the camera to video I could use P and update the firmware I had loaded onto a formatted memory card!
Hope this helps someone else!
这个答案有帮助吗?
得分 1
添加一条评论
I had this problem toobut the solution is to deactivate the autocleaning. The it shoots nornaly
这个答案有帮助吗?
得分 0
4条评论:
I have this problem too and have format the card but still writing error 70
完成的
Please help me
完成的
Have AUTOCLEANING set to OFF
完成的
Please check image Sensor
完成的
添加一条评论
Hi, i fixed this error on my EOS 600D with Tornado EOS program. Do factory reset and problem solved.
这个答案有帮助吗?
得分 0
1条评论:
what do you mean Tornado EOS program?
完成的
添加一条评论
I faced the same issue on my 60D.
Tornado EOS programn is really awesome! I used the free version to upgrade the firmware and problem solved!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tyler Vaal 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 55
总计 25,766
