跳转到主内容
加入维修社区 - 创建账户
Trio Stealth G4 是由 Mach Speed Technologies 制造的一款平板电脑,配备 7.85 英寸高清触摸屏。该设备支持 Wi-Fi、蓝牙和 Google Play,特色功能包括四核处理器以及前置和后置摄像头。
How do I reset my password?
I forgot my password and can't get into my tablet. How can I reset it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
9条评论
One of them told me to go to my setting or widgets but HOW WHEN I CANT LOGIN
完成的
Power volume + only resets it. Still asks for password. Help please.
完成的
Yea how wen it asksnfor password to do anything.
完成的
there are many ways, hope it can help you:https://www.isunshare.com/windows-10-pas...
完成的
Hi @ Elina ANN,
The Trio Stealth G4 is an Android tablet, not a Windows tablet.
完成的
显示更多的4条评论
添加一条评论
2个答案
最有帮助的答案
Hold down Volume + button and Power button at same time. When screen comes on let go of Power button. When the large Android shows on screen let go of Volume + button. Use Volume – button to scroll to Wipe Data/ Factory Reset.
这个答案有帮助吗?
得分 2
3条评论:
Will this cause me to lose all my pictures and data? Is there any other way to reset just the password without resetting the entire device?
完成的
Unfortunately you will loose your data. It is the security design, no point in having a password to protect your information if there is a way around it.
完成的
I have a used Trio Tablet Mst-1041 and another smaller generic tablet that was given to me because the Passwords were either forgotten or corrupted & I am trying to do a "Hard reset' on both of them also.. When the Power button & Vol+ is used it boots into the normal window asking for PW.. When the Power button & vol- is used it boots into safe mode still wanting a PW. These answers here are not helpful at all, there must be another way to do hard resets on these tablets. Any viable answer will be highly appreciated since I really hate to throw away two perfectly working tablets just because of a stupid Password lockout.
完成的
添加一条评论
If you have enabled Android Device Manager on your device, you can reset your password from the Device Manager website. Follow these steps:
  • Log in to Android Device Manager
  • Select your device
  • Select 'Lock'
  • Enter a new, temporary password for your device and click 'Lock'
  • Enter the temporary password on your device
  • Go to your lock screen settings and disable the temporary password you created.
If this doesn't work or you do not have Android Device Manager enabled, you will probably have to do a factory reset. Follow kris's instructions or check out the troubleshooting guide.
这个答案有帮助吗?
得分 0
1条评论:
How can you "Log" in to the Android Device Manager" when you cant even log in without the "Password" to begin with? The "Issue" is.. The "Question" is... How can you hard reset the Tablet to erase, factory reset or get around the the password requirement. Did you even read the question? Your response was not helpful at all.
完成的
添加一条评论
添加你的答案
Dani Gutwein 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 12
总计 7,680
