跳转到主内容
Dell Studio 1537, model number: PP33L. Released August 2008, with Windows Vista by default. Repair for this laptop is straightforward and requires only common tools.
6 个问题 查看全部
问题已关闭
Wi-Fi button wires was discovered disconnected(3 wires grn/yel/red)
My internet is fed thru this computer from my router, I discovered that the three wi-fi wires colors, grn/yel/red is severed from the Wi-Fi button, what needs to be replaced or repaired?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Well because of what I am looking at and the answer given, oldturkey03 was on the money!
完成的
添加一条评论
1个答案
已选择的解决方案
tgriffin62, since we do not see what you see, consider posting a couple of images with your question. Use this guide for that. From reading your question it sounds like you tore the wires of the circuit board. You could try and resolder those, or replace the complete WiFi/ Power button cable. Here is a video that shows you how to do that, and the part is available at places like this
这个答案有帮助吗?
得分 1
1条评论:
perfect description! this was very helpful as the answer was in two parts. thanks for quick and accurate response!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 62
