跳转到主内容
Furby was a popular electronic robotic toy resembling a hamster/owl-like creature which went through a period of being a "must-have" toy following its launch in the holiday season of 1998, with continual sales until 2000. Furbies sold 1.8 million units in 1998, 14 million units in 1999, and altogether in its three years of original production, Furbies sold over 40 million units.
Why is the speaker making this clicking/ticking noise when it speaks?
This ( i think its a 2013) Furby Boom will speak but it makes a quiet crackling noise when it does, then it blacks out (its on my youtube, Mimi B) ive tried replacing the whole battery and it still did it. Ive heard the suggestion to check its tummy switch, only problem is...i have no idea how to get at it, or even where it is or 'how' to check it really... I'm an electronic newbie. Ack, and these things are so complex! Heelllllp!
Update (10/06/2015)
Here's a few pics of what i got so far, just started taking misc pics showing how much has been tore down thus far...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
So complicated, these new ones have become[image|662996][image|647141]
完成的
Hi MimiB. Maybe this can help you: Furby Boom not speaking
Good luck
完成的
添加一条评论
3个答案
已选择的解决方案
Turns out it had a bum motor, (finally my sensetive dog ears came in handy, after sitting there and listening to that clicking, i got a hunch it sounded an awful lot like a record/cd going around really fast but then really slow after that) actually the physical speaker was fine
这个答案有帮助吗?
得分 1
2条评论:
How did you fix the motor? Mine does this too!!!!
完成的
Since i don't know how to "fix" the dying motor, i did the next best thing and got a working motor from either a 2012/boom style spinning motor and replaced it.....i have a video on how to dismantle or 'skinning' of a 2012 furby or boom, in order to get at the motor
完成的
添加一条评论
Mimi B, here is my answer to a similar question " I would get to the "tummy switch" and check the circuit from there. You do have a couple of choices here. Check the switch, then the speaker. Check the connector for both. You will need a multimeter to check those. Follow the schematic to work on your Furby's voice, and check on here for directions on how to skin the Furby." It is possible that you have a bad speech processor on your Furby, but check the components first Hope this helps, good luck.
这个答案有帮助吗?
得分 0
5条评论:
Humor me here...can you describe where on the board this switch connectson sed circuit boatd? Id like to check it there too, also would you know what setting to have the multimeter on when checking that circuit?...i have no idea how much power goes througj all my old,2005, and 2012/boom furbys so....kinda having to start from scratch here....Furby
完成的
First you'd have to skin your Furby. Follow the first link. Then post a couple of images of what you see with your question. 在已经存在的问题里加入图片
完成的
Ive got him skinned and many of its boards are uncovered now (hopefully ugh, these have so darn many), so now what?.....
完成的
Now post some pictures so we can see what you have.
完成的
Pictures showing.......what perhaps, plus my tablet is being stupid. Its not letting me upload pictures on here right now, aaaaargh
完成的
添加一条评论
Hi Mimi B,
This answer can maybe help you:
I just did surgery on my sons furby and fixed this problem. His would move and no sound would come out. Keep the Furby on and go to the right side of the Furby which is where the speaker is located. Cut a small slit in the fur, small enough that your kids won't notice. if you look underneath the fur you will see the speaker. It is plastic and it has a whole bunch of holes in it. Right under the plastic there is a membrane sort of things. I found it when I took a nail or something small and pokey that fit through the holes and gently gently pushed on the membrane in certain spots it would start making noise again. Must have a short or something in it. Once you find the spot that let's it start making noise again find a very small, about a centimeter long, machine screw which is the kind that don't have a point on the end of them but are flat instead. Screw it into the hole until it pushes against the membrane and leave it there, and that should keep it talking. This should keep your kids happy
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mimi B 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 45
总计 9,836
