跳转到主内容
Nose, ear and beard hair trimmer with a dual edge blade. Easy to clean.
Why is my trimmer not turning on?
I have not used my trimmer for a while and now it is now turning on. I already changed the battery but it still does not work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
I bought the ER430 and it runs and then stops.
I cant figure out why this happens
完成的
I removed the top part and then the gear turned. When I put it back together it worked
完成的
i took top off then clear out the opening in back below the cap that shows arrow to open aperture that had hairs in it. then it worked again.
完成的
WD-40!
I've had a Panasonic ER-GN30 nose hair trimmer for years, although I don't use it often and I'd say I take good care of it.
It has always seemed to perform as though it has a low battery. I first noticed corrosion on the negative battery contact, the one up in the body of the unit. I treated it with Caig Deoxit D5 (an amazing product) which helped, yet the issue continued to return.
Recently, the trimmer stopped working all together. I used a power supply to "bump it" with 3v which got is spinning. So I know the switch is good and the motor "can" turn.
I removed the battery and pointed the trimmer blades toward the ground and then liberally sprayed WD-40 up into the body of the trimmer. I sprayed a lot, enough to completely saturate the internals. Then I tipped it over and used some compressed air to blow out any remaining fluid.
The trimmer once again works great, the blades spin at full speed again.
完成的
Can you please post the picture of Panasonic ER-GN30 Switch. After dismantling the same while fixing it one U shaped plastic clip fell off . I don’t know from where it was fixed. However my machine works fine even without that clip.
完成的
添加一条评论
2个答案
已选择的解决方案
Since you have not used your trimmer for some time, there is a good chance the battery or switch leads are corroded. Check out the troubleshooting page for more information.
这个答案有帮助吗?
得分 1
添加一条评论
WD-40
Mine ER-GN30 has always seemed to perform as though it has a low battery. I first noticed corrosion on the negative battery contact, the one up in the body of the unit. I treated it with Caig Deoxit D5 (an amazing product) which helped, yet the issue continued to return.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alejandro Garabatos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 32
过去 30 天: 163
总计 19,155
