跳转到主内容
The HTC EVO 3D is an Android smartphone developed by HTC released exclusively in the United States through Sprint.
9 个问题 查看全部
问题已关闭
Why is my battery life bad? Why does my battery not charge?
My battery doesn't last as long as it used to. My battery only lasts a fraction of what it is supposed to and at times it doesn't even charge. Can someone please help me figure out what may exactly be causing this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your battery is probably damage. In this case, you should go and buy a new one. Also, you will need to check if it correctly installed. In other cases, the fault may be of the charger. If the charger is not working correctly or if it’s broken it won’t charge correctly the battery. Refer to the Troubleshooting Page at www.ifixit.com/Wiki/HTC_Evo_3D_Troubleshooting for more details in order to fix this issue.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Matthew Pope, sounds like you will require a new battery. This teardown will show you how to get to the battery.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 107
