跳转到主内容
加入维修社区 - 创建账户
Nvidia Shield Tablet 第一代于 2014 年 7 月发布。该设备通常用于游戏,具备 Wi-Fi 和 LTE 功能。
Why is my battery dying so quickly?
My battery doesn't hold a charge for my Shield Tablet, is this a common problem, and do I need a whole new battery to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
how old is the tablet and how much use does it get
由完成的
添加一条评论
6个答案
已选择的解决方案
You could be experiencing this problem due to a range of factors. One option is that your battery could be going bad and will need to be replaced, however that is a last resort fix and should be avoided until you run out of other options. I would first try some other possible noninvasive fixes. Try turning down your screen brightness and turning off your Bluetooth when not in use. Avoid running your device down to the last percentages of battery as this reduces the life of the battery dramatically over time. If you enjoy using your tablet while it is on the charger this can contribute to a shorter battery life for the devices current charge.
The charger could also be the issue. If you are not using the cable that came with the device as it's primary charging cable this could be a contributing factor. If you are using a third party USB cable that plugs directly into an outlet the improper voltage/amperage can harm the battery permanently. Make sure you are using the correct charger for your devices. Depending on the device overnight charging can be harmful as well.
There are many factors that contribute to a rapidly dying battery, most of which are preventable by changing a few habits surrounding the usage of your tablet.
这个答案有帮助吗?
得分 3
添加一条评论
you need to find out what batery is in it.
the shields from june 2014 to june 2015 have a bad batery.
check out google for the information how to find it
这个答案有帮助吗?
得分 1
添加一条评论
You should update your shield tablet to 3.1.1 (android 5.1.1).
After that go to settings -> about tablet -> status.
Now it displays your battery type. If there it says Y01 you're in for an replacment.
Follow that directive here:
http://tabletrecall.expertproductinquiry...
I also have one with bad battery and got an replacement.
这个答案有帮助吗?
得分 1
添加一条评论
What you are describing is a common problem among all greatly used batteries. Yes you do need a new battery
这个答案有帮助吗?
得分 0
添加一条评论
The cable of the charger is damaged.
这个答案有帮助吗?
得分 0
添加一条评论
Has anyone had the chance to replace the Mico charging port on the Nvidia shield having problems with the charging AND IT'S NOT THE BATTERY been there n done that. So if someone has change the charging port let me know thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Molly Bauer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 27
总计 12,722
