跳转到主内容
加入维修社区 - 创建账户
Syma S107 是一款小型遥控直升机,采用陀螺仪技术实现稳定飞行。这款直升机采用电力驱动,专为室内飞行设计。
fail to vertically lift
Helicopter fails to lift off vertically. Will lift approximately 1" at full throttle and no more.
Heli is fully charged and batteries are brand new in transmitter. Any recommendations for fixing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
Replace the main rotors. If they've been banged up enough, the lift normally generated will be greatly reduced.
由完成的
添加一条评论
3个答案
did you replace any part?
这个答案有帮助吗?
得分 0
添加一条评论
Yes but also green led light starts flashing and helicopter wings stop moving.
这个答案有帮助吗?
得分 0
添加一条评论
Similar problem with our brand new s107g. Will not liftoff, and moving the directional control to the right results in visibly greatly diminished power, sounding about half speed of full throttle. We had an S107g a few years ago, it flew fine regardless of any crashes, over the course of a couple years. Thoughts?
这个答案有帮助吗?
得分 0
2条评论:
The diminished power is normal for coaxial rotored helis. In order to turn, one of the two counter-rotating rotors must slow down in order to generate a net torque, or turning force. That’s also why coax helis tend to drift up or down while turning.
It sounds like the heli is not getting enough power. Either the battery is not supplying enough, or the motor is possibly worn. Try cleaning all the gears.
由完成的
I have this problem also don't know where to glue
由完成的
添加一条评论
添加你的答案
Deleted 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 37
总计 1,957
