跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
Why is my touchscreen not working?
My screen is on but my touchscreen won't work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
1. touch check
2. touch ic replace
完成的
添加一条评论
4个答案
已选择的解决方案
Depending on the reason there are a couple of different solutions. If the screen is frozen, it will need to be rebooted. Either by holding the power button down for 10 seconds, or the power button and "volume down" button at the same time for 10 seconds. After it restarts, the touchscreen should be working. If it's still not working, the digitizer may need to be replaced. You can find the steps in more detail on the troubleshooting page
这个答案有帮助吗?
得分 8
2条评论:
touch ic replace
完成的
Happens on mine after blue tooth mouse has been connected. OK after reboot
完成的
添加一条评论
Try rebooting or if that doesn't work a reset Hold power button and volume down button together for 10 seconds. If these did not work there is a chance you damaged the digitizer if the tablet was droped or suffered a blow of some sort.
这个答案有帮助吗?
得分 3
1条评论:
you going service senter
完成的
添加一条评论
Mine did this I just slapped it till the digitizer went back and it worked and still does 2 yrs later
这个答案有帮助吗?
得分 1
添加一条评论
tank you somuch i am happy
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jordan Soto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 16,438
