跳转到主内容
加入维修社区 - 创建账户
Epson WF-2540 是一款多功能彩色喷墨打印机。它配有一个 2.5 英寸液晶触摸屏和四个独立墨盒。
Cannot install on windows 10
Original Post: Epson WF-2540 printer
Cannot install Epson printer WF-2540 setup will not fully install the drivers. I have this problem on both computers. Before when I had windows 8 I had no problems, I upgraded to windows 10 cannot get printer to work. What can I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Try running in Windows 7 compatibility mode
由完成的 分享
In compatibility mode where you see Windows 7 or 8 remove the check mark. Restart your computer then try again. Worked for me.
由完成的 分享
hi...you can also get help from this post . it helped me in getting my drivers up and running. http://driverrestore.com/how-to-download...
由完成的 分享
添加一条评论
4个答案
已选择的解决方案
Boot up in Safe Mode and see if it will install. That failing,
Try the instructions here: http://www.epson.com/cgi-bin/Store/suppo...
这个答案有帮助吗?
得分 1
1条评论:
The web page is no longer available.
由完成的 分享
添加一条评论
Mine works... I just used the add printer feature in windows and let it find the printer and load the drivers... No issues. Try it that way.
这个答案有帮助吗?
得分 0
添加一条评论
hi...the link in the answer above is not working, meanwhile you can also get help from this post . it helped me in getting my drivers up and running. http://driverrestore.com/how-to-download...
这个答案有帮助吗?
得分 0
添加一条评论
Epson have drivers for Windows 10 x64 and 32 bit (among other OS)
https://www.epson.no/support?productID=1...
I have installed it and it works on Windows 10 x64 1803.
The printer otherwise is a piece of junk. scanner ADF does not accept any paper thicker then Rizzla cigarettes paper.
But most infuriating, the printer refuses to print anything unless all 4 ink cartridges are read not empty. So if I have a new black ink installed, and only want to print in B&W or greytones the printer will refuse. This is to help me.
I will never buy Epson again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Murven Kelley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 13,694
