跳转到主内容
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98 个问题 查看全部
coffee grounds into the area where the K Cup is
HI. I have had same problem with my Model B60 refusing to close.
I'm not sure what happened with mine, but I ended up forcing it to close.
DO NOT DO THIS
Check near where the silver handle used to close on the K Cup is attached to the machine. Mine has 2 screws on the underside of the silver-colored handle which were loose. They're located on underside of silver-colored handle which is used to close the machine to brew - very close to where handle attaches to the unit. Look for one screw on each side of silver handle - my machine has screws that required screwdriver bit CRV-T15.
Possibly these or some other screws have become loose not allowing things to line up properly & close completely.
Also, I looked carefully at the photos posted by both schmick & @oldturkey03. I noticed schmick's photo of the needle on the top (center photo) appears to not have a black rubber washer or seal or whatever it is called, which I can see in photo posted by @oldturkey03 (3rd photo from top - 2nd to the last of photos-from top to bottom)
Hope I helped somebody
My Keuring Model B60 is currently spewing coffee grounds into K Cup area & a little into the cup, but still brews.
Not sure, but, I think my problem might be the following: After it refused to close & I forced it to close it brewed but grounds were in cup & in machine. I adjusted the silver-colored handle - screw had loosened. I also removed the black rubber washer or gasket. I wasn't sure which way it went when I replaced the black rubber washer-thing, so I'm hoping it's upside-down????
Anybody have any ideas?????
Would be appreciated. My machine brews fine, isn't slow or not filling the cup. It's just getting the coffee grounds into the area where the K Cup is placed & also some grounds into the brewed coffee...
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
It s the recyclable pods. The tops are more flexible and the pressure pushes the top down into a concave shape. When it goes too far down (not all the tops are consistent) the coffee grounds, or whatever else is in the cup, backwashes out the hole in the top made by the needle. Here’s the interesting part: Keurig just told me on the phone that the only recyclable pods they support are their own and if we buy other recyclable k-cups that’s our problem. I had suggested making a better grommet but they said are not interested in supporting other manufacturers of k cups.
完成的
添加一条评论
1个答案
已选择的解决方案
gumbypokey1960, it could be possible that this is caused by reversing the gasket. Take a look at this guide step 2 for a proper positioning of the gasket.
这个答案有帮助吗?
得分 1
2条评论:
Hi, there. You're quite knowledgeable about these wonderful coffee brewers.
I think your're right on the money. After I located this cool site, I checked the black rubber gasket thing on the top part that closes.
It was upside-down when compared to your helpful guide on cleaning out the Keurig.
I flipped it over. It still leaked grounds a bit. Remember I stated how I had forced the silver handle on my Model b60 down when it refused to close completely.
I found the 2 screw on each side of the silver-colored handle were loose, so I tightened them. I must not have had everything lined up properly, because it continued leaking grounds, but not as many. I then, after reversing the black rubber gasket it leaked very few grounds, I then loosened the 2 screw back up to adjust the position of the handle when it closes, hoping all would line up.
After the minor adjustment & reversing the gasket, it doesn't leak grounds anymore.
Much better.
Thank You Very Much
Gymbypojey1960 :);)
完成的
YOU ARE PROBABLY GOING TO HAVE MORE PROBLEMS.... THERE IS AN EASY FIX ON EBAY FOR $3 AND IT'S GUARANTEED. The coffee is bubbling up and out of the K-Cup because it's not draining out properly and/or there isn't enough pressure on the K-Cup lid to keep the seal pressed hard against the foil top. The ebay fix-it-kit solves both of those problems and it works!
https://www.ebay.com/itm/271684395896
完成的
添加一条评论
添加你的答案
gumbypokey1960 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 30
总计 7,572
