跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
ipad air LCD not turning on after digitizer replacement
hello , i got the same problem with my i pad air 5 where screen stays black after digitizer replacement. funny thing my battery was disconnected during replacement. any ideas?
i tried reseating clips, home button and off button hard reset old digitizer also not working.
I pad is detected by iTunes and when i connected the charger the charging sound keeps beeping continuously. please advise
Update (09/15/2015)
I think I found the problem. does any one know what this part is called and how to go about it. my soldering skills are rubbish. is it a fuse of some kind. how could this have happened if I was wearing static band and battery was disconnected.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The backlight filter is possibly blown. I have run into on either a mini or an ipad air, I don't remember which, a situation where I thought I had killed the backlight filter but it tested good so I put a different lcd on it and it worked. After that, I put the original lcd back and it worked fine. I never did figure out what was screwed up but it may be worth giving a try.
Gotta try the easy fixes before chasing after the board work so try a different lcd first. Maybe even disconnect the battery and let it sit for 30 minutes or so disconnected and come back to it. They're finicky.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
frankmasiko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 653
