跳转到主内容
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
20 个问题 查看全部
Why is my jack not connecting my speakers?
I have speakers that I'd like to use. But, when I connect the jack no sound comes out. The speakers are turned on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Check your pref settings. Also make sure you plugged into the headphone outlet and the speakers do in fact work.
Update (09/02/2015)
Go to the Apple menu there you'll find the menu choice System Preferences ... Select it and a window will open.
On the second row at the far right you'll see a speaker icon Sound click on it, that will open the pref settings for sound make sure the Internal speakers are set and the output volume is set to the louder side of the slide and the balance is in the middle.
这个答案有帮助吗?
得分 3
2条评论:
what is pref settings and where are they?
完成的
I know what pref settings are. Hope it'll help. Also need to check speakers.
完成的
添加一条评论
添加你的答案
Jo Anne Brieff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 7
总计 243
