跳转到主内容
加入维修社区 - 创建账户
Garmin Nuvi 255W 是一款 GPS(全球定位系统)设备。
Can USB Port be replaced
Can the USB Port be changed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
johnstopka, yes it can, but you may have to hunt for a replacement. Remove the logic board, remove the EMI shield which covers the IC's and the port. Then unsolder the old and resolder a new one. Consider purchasing a broken Nuvi to harvest the port. Here is the guide for the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
If it is either because you need something off the device or for the sake of repairing a device and feeling the joy of being able to then go ahead. Otherwise get a used one. It will make more sense to your time and pocket. Just looked up on ebay really quick and they are not even $40 for a used one
这个答案有帮助吗?
得分 0
2条评论:
The problem is My 255W has Free Lifetime Maps and don't want to lose that
完成的
Hi @vwtraveller ,
Contact Garmin about a repair. According to this it states:
".....if your device should ever fail AND if it is repaired or replaced directly through Garmin. If the device is repaired or exchanged through Garmin, either under warranty or outside warranty, the nuMaps Lifetime subscription and all other downloadable content & mapping products will transfer once you complete a Device Exchange in your myGarmin account. See Related Content for detailed instructions. If the device is exchanged through a dealer, contact Product Support to provide an exchange receipt."
完成的
添加一条评论
添加你的答案
johnstopka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 702
