跳转到主内容
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
90 个问题 查看全部
Why is my Xbox 360 PC wireless controller stuck on player 2?
my Xbox 360 PC wireless controller is stuck on player 2, sometimes player 3. It used to be on player 1 , but now I cant use it, I checked drivers, removed some usb drivers, checked device and printers... but still it displays the player 2 light. :(
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
I solved the same issue, at least for me. If you have any game streaming service (Such as Kinoi Streamer or the like) Remove it!!! That auto assigns itself to player 1, thus defaulting your controller to player 2! I Uninstalled it, and my controller defaulted to player 1 again!
这个答案有帮助吗?
得分 23
13条评论:
Yup, that's what it was for me. You rock man.
完成的
That was exactly it! Thanks dude!
完成的
i tried doing the drivers thing for about a week straight and was baffled, i wish i had found this answer sooner. it worked pretty much /instantly/
完成的
yes that what is was for me thanks you nicky ! :d
完成的
Wow! Thanks man!
完成的
显示更多的8条评论
添加一条评论
Carlos Daniel, I'd start by trying to resync the controller. Check on here Should it still do this after, try a different controller. This will determine if the controller is sending wrong signals or the receiver board is failing. some of it will depend on which version Windows you are using.
这个答案有帮助吗?
得分 2
添加一条评论
I guess another wire controller is connected to your PC. It is defined as player 1. That's why your controller stuck on player 2.
这个答案有帮助吗?
得分 1
添加一条评论
Did not work.
Windows 10, all game controllers default to player 2.
Tried restarting,
uplugging and restarting,
deleting drivers and restarting,
removing al streaming software, deleting drivers, and restarting,
still the controller will not work.
这个答案有帮助吗?
得分 0
2条评论:
Ok, it does work, it just doesn't look like it would.
The player two LED lights up, but when I turn on a game it allows me to play it with the controller.
I guess as long as I don't look at my mouse while the game is on, I should be fine.
Thanks guys.
完成的
try using this https://goo.gl/akhQg2
完成的
添加一条评论
添加你的答案
Carlos Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 43
总计 48,879
