跳转到主内容
加入维修社区 - 创建账户
型号 A1419 / EMC 2806 / 2014 年末或 2015 年中期。3.3 或 3.5 GHz Core i5 或 4.0 GHz Core i7 (ID iMac15,1);EMC 2834 2015 年末 / 3.3 或 3.5 GHz Core i5 或 4.0 GHz Core i7 (iMac17,1)。均配备 Retina 5K 显示屏
Glass Over Screen Broken
is it possible to replace protection glass over the screen ?
thanks for answer
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
8条评论
Please give us the last four figures of your serial number located on the bottom of your stand.
由完成的 分享
serial #C02NG8ULFY11
ENC # 2806
由完成的 分享
Apple iMac "Core i5" 3.5 27-Inch (Retina 5K, 2014) Specs
Identifiers: Late 2014 - MF886LL/A - iMac15,1 - A1419 - 2806
由完成的 分享
Many thanks for your answer
One Ring to rule them all....
when reality reaches fiction
由完成的 分享
Hi all!
I'm having difficulty determining what replacement glass I would need ... last four of serial is ...GG77 ... it's an early-2015 iMac 21.5" with broken screen glass. Works fine, is actually usable despite the crack across the screen. I don't think it's a Retina display. (I'm considering purchasing the iMac, but a lot depends on being able to replace the glass.)
由完成的 分享
显示更多的3条评论
添加一条评论
6个答案
已选择的解决方案
Apple in its infinite wisdom and cost cutting measures has now fused the glass to the display. So it only comes as a complete unit. Here's how it's replaced: iMac 英特尔 27 英寸 Retina 5K 显示屏更换
Apple Part #661-00200
Reports have been posted of some that have separated the glass but none repaired successfully.
Most units available in the USA cost around $500. A China seller on eBay has it for $310 + $65 shipping. Warning, check the ratings on these sellers.
这个答案有帮助吗?
得分 4
1条评论:
Are you sure about that part number? When I search it I find screens for the older, non-Retina 27" iMac.
由完成的 分享
添加一条评论
For small cracks (as long as there’s no missing piece of glass), I used windshield repair kit for cars, and it made the crack almost invisible. Costs about 10 bucks.
这个答案有帮助吗?
得分 3
4条评论:
And it worked for you?
由完成的 分享
The crack is still kinda visible, but only from certain angle, and only when I'm looking up close.
由完成的 分享
Wow, that's clever! I'll try it on mine.
由完成的 分享
I'm really curious about the performance of the glass repair liquid. Is there still a chance to upload a photo? I have a chance to get a cracked screen for a very cheap price of 100 usd. Is it worth it ?
由完成的 分享
添加一条评论
Buying a functional iMac 5K with broken glass right now for a cheap price.
Wondering if anybody has found a glass part anywhere ?
I have a 2011 27in laying around the house, has anybody tried using that one ? Maybe by cutting off the metal parts at the bottom, it could fit ?
Thanks for your help.
这个答案有帮助吗?
得分 1
添加一条评论
It can be done, I have done it, I can’t find the actual glass anywhere for purchase, heat and air suction vacuum is the answer.
这个答案有帮助吗?
得分 0
4条评论:
Are you using it 'commando' or found glass part somewhere?
由完成的 分享
Where can the glass be ordered from ?
由完成的 分享
Hey, can you maybe outline your actions, in order to replicate that procedure? Thinking about doing the same. Did you just heated up the glass with a heat blower and peeled if off from the screen? Were there any remaining glue components on the display? Or was it something more sophisticated?
由完成的 分享
Please let us know more, I have a 27inch 5k 2017 imac i need to replace the glass on and dont feel like paying $600 for it
由完成的 分享
添加一条评论
Does anyone know if the dimensions of the a1312 glass panel and the the a1419 panel are the same?
这个答案有帮助吗?
得分 0
添加一条评论
Could you try fitting the 2011 glass to it and letting us know how the dimensions compare with removing the metal bottom pieces ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alain Buffello 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 72
总计 37,793
