How to replace the ballast on my Mitsubishi WD60735
Is replacing the ballast the same in the for the wd 60735 as in the one you showed, if different how much different? could I get a picture of how to replace it if different.
Ronnie Rutledge looks straight forward. The ballast is mounted to the optical engine assembly. It might help if you post some pictures of what you are looking at after you removed the back panels. "BALLAST ASSEMBLY REMOVAL
REMOVAL PROCEDURE
1) Remove screw (A) from the Ballast support and screw (B) if the Engine is still mounted in the cabinet.
2) Slide the Ballast Assembly out the rear of the Engine assembly and unplug the Lamp connector (C) at the Ballast.
3) Disconnect connectors CJ1 and CJ3.
4) Remove screw (D) to remove the PWBBALLAST from the Ballast Support.
Reverse the procedure to install a new Ballast ." is what the service guide suggest.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 358
