跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
MacBook Retina Pro 2013 - Broken Right Fan ZIF socket
I recently spilled beer on my laptop (Early 2013 15' Macbook Pro Retina), resulting in some corrosion on the connection between the logic board and the top case/keyboard. I soaked it in iso alcohol and removed the corrosion with a fine brush. After putting it together, it works fine (as far as I can tell)!
Unfortunately, when re-assembling the laptop, I broke the retaining flap on the right fan ZIF socket. For reference, it's the socket shown here:
https://d3nevzfk7ii3be.cloudfront.net/ig...
The socket is still intact, and the cable fits in it, but I think without the plastic latch/flap the cable won't engage. I put some electrical tape under the cable to hold it parallel but that doesn't help it engage with the socket.
I ran the apple hardware diagnostic tool (startup while holding the 'D' key) and it gave me this error - 4MOT/4/40000002 - Right-Side-0. It seems like the laptop can't recognize the right fan without the socket being locked down.
Is there any way to fix just the flap? Or the ZIF socket? I have some experience doing SMD soldering so it's not out of the realm of possibility to replace the socket itself if I can find the part.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Thanks! Do you know any UK distributors that stock this part?
完成的
添加一条评论
2个答案
已选择的解决方案
Cam Bennett, the connector is a FF14A-5C-R11DL-B-3H. It is available at places like this and many others. The only proper way to fix this would be to replace the connector.
这个答案有帮助吗?
得分 2
添加一条评论
How did you fixed this? Same problem here
这个答案有帮助吗?
得分 0
1条评论:
I'm sure Cam got the replacement connector from part info and link @oldturkey03 gave her. Then either had the skills to replace it or got someone with micro soldering-skills to do it for her.
完成的
添加一条评论
添加你的答案
Cam Bennett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 1,672
