跳转到主内容
加入维修社区 - 创建账户
发布于 1995 年 8 月 28 日。搭载 33MHz 处理器。
open firmware on PowerBook 190
How can i boot into the open firmware of a PowerBook 190? I've tried the Cmd+Option+O+F command but it doesn't do anything
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Here's everything you ever wanted to know about open firmware on System 9;
http://www.netneurotic.de/mac/openfirmwa...
这个答案有帮助吗?
得分 2
7条评论:
If I'm not mistaken the 190 is a 68K machine and does not have open firmware. + for research. Ralph
由完成的
Ralph, If I remember correctly it was a 33MHz 68LC040 processor. Which means you're right about the 68k cpu, I just don't remember about the open firmware.
由完成的
I was afraid of that... Do you know of anyway to get around the startup disk issue. The exact message is "This startup disk will not work with this Macintosh model. Use the latest installer to update this disk for this model." with a restart button. The computer was working fine but one day it just locked up, shut off, and now this happens everytime it turns on. Also, the hardware seems to be okay as the little happy Mac picture comes up when it turns on too.
由完成的
What startup disk are you trying to use? What other system disks are available to you?
由完成的
As far as I know it should still have the hard disc set as the startup disc (I'm not entirely sure though, I'm not as familiar with a Mac this old). And at the moment, I don't have any system discs that are compatible (as it only has a floppy drive and no way to connect a dvd drive)
由完成的
显示更多的2条评论
添加一条评论
添加你的答案
Tanner 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 21
总计 1,234
